09-11-2019, 06:25 AM
(This post was last modified: 09-11-2019, 06:43 AM by drbacke. Edited 5 times in total.)
I asked myself, if it would be possible to add a lto battery Bank before (parallel but physacl. before the 18650 Bank) my 18650 Bank.
The idea is to increase the lifespan of my 18650 bank with few lto batteries. Just like using capacitors to get rid of the voltage spikes.
So i currently use a 7s60p. the voltage is between 23.1V and 28.7V
With 11s1p lto (30-40ah) the voltage range should be covered.
The difference to add just more batteries would be the different infernal resistance. (Lto is mich lower) so they should be more loaded than the 18650s. What do you think?
I ordered currently 1 yinlong lto ti check the quality of the cells
