Threads: 37
0
Total Cells:
Total Capacity: 0.00 kWh
09-21-2019, 08:30 PM
(This post was last modified: 09-21-2019, 08:32 PM by Jonisingt35r. Edited 2 times in total.)
hello
im just started to build my battery, and looking for inverters, wondering if my cell count is right im going to build a 14s and charge my cells 3.6 to 4.0 therefore my bettery will
go from 50.4 to 57.4v, do inverters tolorate overvolting up to 57v?
thansks
Battery is li iron using 18650s, 14s, 0p, and growing cell so far 300, untesteded.
Bms is a diy open source by stuartpittaway.
No solar yet,
Building wind turbine, 48v im after a 48v motor if anybody has one for sale.
Cells 2000 to 2500ma.
Cells 1500 to 2000ma.
Cells 1000 to 1500ma.
Threads: 4
8
Total Cells: 5034
Total Capacity: 40.34 kWh
09-21-2019, 10:25 PM
(This post was last modified: 09-21-2019, 10:31 PM by OffGridInTheCity. Edited 5 times in total.)
14s 18650 is probably the most common config and fine for a wide range of inverters. I have used Reliable inverters in the past but settled on AIMS for a more robust 24/7 usage. I think you'll find that almost every 48v inverter will be fine.
Threads: 28
86
Total Cells: 29600
Total Capacity: 146.46 kWh
If you dont know what gear you are going to use 14s is the safest bet for sure. It fits 99% of all 48VDC equipment very well.
YouTube /
Forum system setup /
My webpage Diy Tech & Repairs
Current: 10kW Mpp Hybrid | 4kW PIP4048 | 2x PCM60x | 83kWh LiFePo4 | 10kWh 14s 18650 | 66*260W Poly
Upcoming: 14S 18650~30kWh | Automatic trip breakers, and alot more
Threads: 37
0
Total Cells:
thanks
No solar yet,
Threads: 9
0
Total Cells:
09-23-2019, 07:51 PM
(This post was last modified: 09-23-2019, 07:52 PM by Doin it.)
Korishan.. what solar charge controllers go up to 64v and can charge lithium? U said there’s a lot.. I’ve been searching and only found the victron and midnite that can charge to 64v..
Threads: 54
11
Total Cells: 300
Total Capacity: 2.78 kWh
If trying to fit lithium into a lead-acid battery voltage range, 14s fits most all 48v hardware very well.
7s = 24v lead
10s = 36v lead
14s = 48v lead
I have come across a lot of equipment that accept higher input voltages as well… I am working with a 15s system as my EV batteries are in 5s modules wired 3 in series, but that does limit some options when searching for equipment. I have observed most of the most of the well know or commercial brands out there don’t have a problem with this. Victron is generally my first choice for MPPT Charge controllers, inverters, and DC-DC converters.
Threads: 1
0
Total Cells:
I see everyone here keeps referring to 14s as 48v. That's going to mislead more than a few. In the ebike world and with BMSs, 13s is 48 volts and 14s is 52 volts. It makes a big difference when buying a BMS.
