OffGridInTheCity said:Its a great reminder that details matter. Its what makes the discussions on this forum so interesting.
not2bme said:Interesting. So the moral of the story is to properly size your car battery to the alternator.
not2bme said:They used a 3.6kwh battery at 50% SoC. That's rather large. A car battery only needs to have a high cranking amps, not high capacity. A lithium battery should always be at 80-100% SoC (unless you left the car unused for over 2 years) and if properly sized it should have been charged and should reach absorbtion charging stage relatively quickly and the current draw would have been reduced dramatically.
Korishan said:I would say it's best to size your alt to your battery. In these types of cases, the battery is built to handle a certain type of load beyond what the vehicle was originally designed with or could handle, and/or for use while the engine is turned off. Then charging is done when the engine is started when leaving/moving/etc.
They used a 50% SoC battery strickly to draw the most amps possible as they wanted to demonstrate the possible/max loads that would be stressing the alt. I agree that normally the battery would only be 70-80% SoC as the lowest.
In the video they demonstrated what would happen if the alt ran at lower rpms. This is what caused the issue. And note, it wasn't the heavy load that destroyed the alt, but the lack of air flow keeping the alt cool.
This is the biggest problem using a standard alt to charge Lithiums, or any battery really. As he stated, an alt is only about 50% efficient, due to the heat produced. The reason there is heat is because the alt is self energizing. There are no magnets. If you were to take out the field coils and replace them with neodymium magnets, the efficiency would drastically improve. However, I'm sure there's more to it than that to do a conversion.
Korishan said:And yeah, I agree it wasn't a lithium issue.
OffGridInTheCity said:At one point, it sounded like they were saying that Lead Acid has such a high IR ... the Lead Acid could *not* accept (and soalternator does not produce) as many amps as the Lithium-Ion with lower IR / can accept more amps.
It seems like a large Lead Acid battery bank would also 'overdraw' on an alternator - since multiple Lead Acids in parallel could 'accept more amps' - same as Lithium-Ion in the test.
Does their statement about a regular car battery not being able to accept very many amps so alternator will not overheat at idle make sense?
