I thinks me need a Daromer!!
Yep, a normal bulk/absorption/float LA algorithm when suitably set for the lithium voltage requirements will work just fine.
It needs a little tweaking of the absorption timer and setpoint, and you can run a risk of overcooking your balancing/bypassing resistors, but it does work.
