chuckp
- Jul 29, 2018
- 415
Here's my problem (Sorry if this has been discussed before) coms ain't my thing.
Sofar solar Mass Energy ME3000SP AC Coupled charger inverter has an RS485 coms port that takes an RJ45 lead out to the BMS.
I have at the moment a cheap 14S 100A Chinese BMS
https://www.aliexpress.com/item/32828948173.html?spm=a2g0s.9042311.0.0.8de94c4dDWRTkM that has a RS232 coms for a three wire Bluetooth or a four wire PC module.
Question is how do I connect the two together and get them talking nicely to each other.
Would an RS232 to RS485 converter like this work?
https://www.amazon.co.uk/gp/product/B01LVVI1XI/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Obviously I'll need to get a DB9 male to RJ45 and a DB9 female header if this would work. Or if not has anyone found a work around that will, maybe using a Raspberry Pi or similar?
The Chinese BMS is only until funds permit a Batrium, but that said it may well be a year or more before that's going to be possible.
Thanks
So I was wondering what was inside the pc module and decided to open it up and have a look.
This is what I found inside.
It has the RS485 connections on the board next to the RS232, so I'm wondering if this could in some way be utilised?
Thanks
