is it better to charge at 500ma, low v cells?
hello
winder if anbody has done studies, if charging low current, low voltage, cells to try to retrive them?
was thinking of starting to test first charge at 500 and then do a 1amp charge
thanks
Bms chinese bluetooth
How low is low V?
If voltage is <2.5V, it's best to charge 250mA or there abouts. If the voltage <1V, better to charge around 100mA, or 50mA. So, basically, the lower the voltage, the lower the charge current.
Checkout @DIY Tech & Repairs youtube "Bump charge/revive your dead or low voltage 18650 cells"   https://youtu.be/n_MKDta9M_I
I am processing 1600 Panasonic NCR18650A(s) from Power2Spare and MANY are low (0.2-0.9) volts.   I took some 18650 battery holders and put a charged cell in slot1 with resistors to slots 2, 3, and 4 as described in the youtube.   Then I pop these 'zero'/'low volt' cells in and leave them for couple of hours and they gracefully go up to 2.0v+ range.   Then I use 500ma charging in my OPUS to get them up to 3.5'ish.  Then on with 1000ma as normal for my test process.     This seems to work best at recovering these - I've had 70% success rate.
Used these 82ohm resistors from amazon - https://www.amazon.com/gp/product/B0002K...UTF8&psc=1
mihit likes this post
thanks,
