cell matching brand new 18650
Hello,
I'm wondering if it's necessary to cell match brand new INR18650-35E batteries? I've tested few and they're +/- 30mah with each other.
I would not match new cells unless it is for HIGH current applications
(10-06-2019, 04:34 PM)daromer Wrote: I would not match new cells unless it is for HIGH current applications
I will be pulling max 3A per cell, that counts?
(10-06-2019, 06:08 PM)saffire21 Wrote: I will be pulling max 3A per cell, that counts?
https://www.orbtronic.com/content/samsun...50-35e.pdf
Model: INR18650-35E
Chemistry: INR
Nominal Capacity: 3500mAh
Continuous Discharge Rating: 8A
Max Discharge Rating: 13A
3A would not be considered HIGH current for these cells. 8A is standard, 13A would be.
(10-06-2019, 04:18 PM)saffire21 Wrote: Hello,
How accurate is your test equipment ?
The negligible +/- 30mAh is likely a combination of a slight cell capacity difference and your testers inaccuracy and repeatability.
High current is when you max out the cells and the ir really start to come to play
Well the more cells you put in parallel the less the need for matching.
