Nemo
- Apr 26, 2019
- 53
I've recently started experiencing a problem with my OPUS charger. Some cells seem to take much longer than normal to charge. There is nothing unusual about the cells (they aren't particularly hot, acceptable IR), and it doesn't happen on the same slots each time. It also doesn't happen every time. I have modded the OPUS with a back fan to avoid temp stalling and haven't seen any evidence this is occurring.
I regularly use the charge test function at 1000mah. Its almost as if some of the slots are somehow resetting to 500mah.
Has anyone else out there experienced this? Any potential solutions?
