Batrium Same Cellvolt Bypass
I have looked all over the Batrium web site and looked all over Youtube etc.  I cannot find a description of what the Same Cellvolt Bypass function does on the Cellmon Bypass Extra Mode.  Does anyone here know?  Thanks,  Richard
https://support.batrium.com/article/62-h...n-watchmon
Batrium Wrote:Same Cell Volt - trigger bypass on any high cell voltage to match low.
Thanks Mike ...still wishing there was an organized manual for Batrium.
(10-12-2019, 12:52 AM)mike Wrote: https://support.batrium.com/article/62-h...n-watchmon
I've used Auto Level a few times when adding new packs, but looking at this - the sub-panel forSame CellVolt is the same as Auto Level - i.e, they are  identical.   So that begs the question : what kicks off Same CellVolt.    The Auto Level is kicked off based on "Bypass Volt" CV9 on the main CellMon screen.  What causes Same CellVolt to engage?
Hi Offgrid .....
Thanks for coming on board on this discussion ...I am wondering the same thing.
Auto Level just has additional criteria that you can set on that screen.
(10-12-2019, 10:58 AM)mike Wrote: Auto Level just has additional criteria that you can set on that screen.
The Auto Level Screen looks like this:
The Same CellVolt Screen looks like this:
I don't see any difference.   Maybe I'm missing something?
That does look odd, but am guessing the setting are ignored for Same CellVolt based on what's said in the documentation. That would be a good question to ask Batrium to be sure I guess.
Quote:Same Cell Volt - trigger bypass on any high cell voltage to match low.
Auto Level - trigger bypass on any high cell voltage to match when the criteria allows this process to run.
If someone does get an answer from Batrium please post it here!
(10-12-2019, 02:49 PM)Headrc Wrote: If someone does get an answer from Batrium please post it here!
Dont use Same Cellvolt Bypass function, it is a obsolete function prior to AutoLevel. The option AutoLevel is available for general public use for chemistry other than LiFePO4. Same CellVolt remains available for a specific customer project that is not for general use, hence why its not documented.
jdeadman likes this post
www.batrium.com provider of battery management for lithium cells
