Rust protection
Hi there, my first post here.
So, I am trying to build a battery pack for a project I have and got some used but still good 18650 cells. Since they were used in another battery pack before they had metal strips welded to the terminals, which leave annoying metal pieces when removed. Since I couldnt get them off with pliers I used a dremel for the last pieces, tho only on a few of them and only on the positive terminals. Coming back a day later I found that most of them started rusting on the terminals. I could get it off with a dremel, but they would start rusting again anyways...
Do you guys know something to put on there that would prevent rusting in the future?
Best regards
Alex
Don't use a dremel on cells. It removes the thin coating that prevents them from rusting. Instead, you can flush-cut wire cutters to snip them off or the flat side of your pliers to tap the small pieces down flat (this is what I do).
As for the actual question of fixing the damage already done, not sure...
Korishan and chuckp like this post
The only way to really keep the cells from rusting further is to drop solder on those spots. That is, to keep it conductive. If you want to protect them till later, use some electrical tape firmly pressed to help protect it from further rust. IMHO
chuckp likes this post
Like Mike and Korishan said, stop using the dremel, use small flush cutting snips and pool a little solder over the ends of the ones you've already done to stop them rusting.
UK Southwest.
Try using a lanolin based spray ie one that leaves a non-conductive protective film on the surface.
Thanks for all the answers. I put some solder on them for now, but will I still be able to spot weld them with the solder?
you can, but the spot weld won't be as solid. Though, it will probably still be tough to pull off. Do a few tests on a dud cell first so you can get a feel for it. You only need a thin layer of solder, btw. Don't need to put a mound. Just make sure to use enough flux (non-acid, non-plumbing)
You cannot spot weld on top of solder. The melting point of solder is way off compare to the other metal.
What do people think of this:
- clean it up,
- spot weld new strip on,
- spray protective coat
It would work i would say. Just beware you really should t spray anything on positive side since ut get into the went holes
chuckp and BatteryMooch like this post
