Nickel Strip with Cell Level Fusing
(10-17-2019, 10:54 AM)boysie Wrote: mine has arrived, but didn't think about how to cut the sections, in my case 8 cells long. I'm guessing tin snips but any other ideas?
Straight-cut tin snips is best https://amzn.to/2VQvHOJ
If you're only cutting a small amount, regular scissors will probably work fine but will dull out eventually.
(10-13-2019, 02:06 PM)chuckp Wrote:
(10-13-2019, 01:42 PM)Oz18650 Wrote: I had the same thought, but then figured you would only use this on the positive side and if a cell needs replacing,  you would push it out the other side?
Then spotweld a new fuse with its surround into place.
True, but i think both sides would be better for the pack aesthetics
Also if going to the effort of making my busbars for one side I might as well just do both sides the same.
Would be great if they could make one specifically for the negative end with a wider opening.
You know you are a battery enthusiast when pack aesthetics become a thing lol.
chuckp likes this post
(10-17-2019, 07:03 PM)Crimp Daddy Wrote:
(10-13-2019, 02:06 PM)chuckp Wrote: True, but i think both sides would be better for the pack aesthetics
I think it's more like OCD rather than enthusiasm or maybe it could be a little of both! LoL
UK Southwest.
I emailed batteryhookup twice last week asking if these are pure nickel and what thickness. No response. Anyone know?
(10-20-2019, 08:47 PM)cowpen Wrote: I emailed batteryhookup twice last week asking if these are pure nickel and what thickness. No response. Anyone know?
They are nickel-plated steel. It says this on the product details page.
https://batteryhookup.com/collections/ce...232.f1131f
Product Details Wrote:These are continuous rolls of nickel steel 6 cells wide
