Where to Buy Battery Cabling
So the garden hose cable is not a good idea?
Cous i am seriously considering it for some parts:
From panels to charger and from charger to the pw.
Thanks in advance
(10-15-2019, 04:30 PM)100kwh-hunter Wrote: So the garden hose cable is not a good idea?
Thanks in advance
Garden hose is not approved for use as electrical conduit. You can pick up 10ft sections of PVC electrical conduit designed for this purpose for cheaper than the garden hose at most hardware stores.
Korishan and 100kwh-hunter like this post
You can also pick up garden variety hose on street corners, but I still prefer conduit.
-Crimp Daddy
I thought about pvc, but i thought it would be static, that's why i wanted in garden hose first and that one in pvc pipes to segregate the positive and negative.
So each hose in a different pvc pipe....
At work i will be very friendly to the electricians(again).
Thanks!
No Kidding
100kwh-hunter likes this post
(10-15-2019, 06:13 PM)100kwh-hunter Wrote: I thought about pvc, but i thought it would be static, that's why i wanted in garden hose first and that one in pvc pipes to segregate the positive and negative.
This is why you use "conduit", not PVC. Conduit is the grey stuff. It is less prone to static electricity. Tho not sure how. You can use regular pvc though, as well. If you are worried about static electricity, just run a thin bare copper strand outside the pipe firmly taping it to the pipe every so often.
However, the only reason static electricity would build up is if something is "rubbing" on it. I highly doubt those electric cables inside are getting that frisky with the pipe Tongue
(10-15-2019, 03:39 PM)Crimp Daddy Wrote: Could you imagine if someone welding without flexible cable =)
It would be quite irritating to be said person.
That would be an awesome april fools joke, replacing the cable on someone's welder with solid core wire.
HMMMMMM Idea's for April...............
Marine or automotive battery cable can be decent & there's lots of auto-electrical places.
The marine stuff is usually tinned wires so less corrosion issues - but your batteries should be somewhere dry & low humidity anyway.....
But still 1 of april....i know my victims habbats.....
jdeadman likes this post
