Voltage configuration in batrium
I'm on site all day tomorrow so can keep a close eye on the charging process. Hopefully we'll see things level out and I can bump my absorption point back up to 55v for the winter.
+1 to daromer's car bulb on the new cell.
You could also use some 5W or 10W resistors, eg 4.7 ohm (for LiFePo4 @3.5V = 2.6W & ~0.75A each) don't the resistors to get too hot...
My longmons are closer together than I'd like due to available space on the battery box - so I have fans on them.
The longmons are mounted to clear polycarbonate sheet.
1x low speed 120mm 12V PC fan easily does each bank of 16x longmons.
I made a manifold out of 5mm corflute sheet & hot-melt glue to direct the airflow better.
The polycarb safety covers have a gap approx 1cm at the top & bottom.
If the fan failed, it shouldn't impact free air flow too much.
Before:
With fans:
daromer likes this post
@ daromer:
Daromer wrote:
Example I have almost 200 mons in total... 200 fans?
I have a suspicion you have more than 200 fans Cool
Lol Smile
