[CLOSED] Update: Nissan Leaf 2015 battery pack 24kWh
[b]UPDATED 23-11-2019:[/b]
Frugal as I am, I have decided to try and use the whole pack as a home storage battery, keeping the case intact.
Therefor the pack is no longer for sale.
UPDATED 30-10-2019:
Yesterday my 2015 Leaf was retrofitted/upgraded with a 2019 40 kWh batterypack  Tongue
I intend to sell my original 24 kWh 2015 battery pack containing 48 modules with a state of health of 83% (11 of 12 bars visible on the dashboard).
The reason for selling is that I will be upgrading my Leaf to a 40kWh pack before the end of 2019.
At the moment I am still driving around with the pack.
I do not have the knowledge or will to use the pack for a storage solution myself but maybe somebody on this forum is interested.
Limitations concerning delivery:
- I will not disassemble the pack as it contains High Voltage components.
- I will not sell individual modules, as this would mean disassembling.
- You will have to arrange for shipping if so desired (at your cost).
- The pack will be attainable in The Netherlands (Europe) only, but you are free to ship it worldwide.
Price:
3250 euro
Battery specs:
I attached a few LeafSpy Pro screenshots of the pack, showing the SOH of 83% and other details.
Battery module specs
Number of cells    4
Construction    2 in-series pairs in parallel
Length    11.9291″ (303 mm)
Width    8.7795″ (223 mm)
Thickness    1.3779″ (35 mm)
Weight    8.3775 lbs (3.8 kgs)
Output terminal    M6 nut
Voltage sensing terminal    M4 nut
Module fixing hole diameter    0.3582″ (9.1 mm)
Cell specs
Cell type    Laminate type
Cathode material    LiMn2O4 with LiNiO2
Anode material    Graphite
Rated capacity (0.3C)    33.1 Ah
Average voltage    3.8 V
Length    11.417″ (290 mm)
Width    8.504″ (216 mm)
Thickness    0.2795″ (7.1mm)
Weight    1.7624 lbs (799 g)
Alberto609 likes this post
Going the MUXSAN way?
Ciao I Am interested at yours 48 modules, and i like to pick up directly in Neverland. (Are the module disassembled from the external case, or still assembled?)
I just send you a private message.
Best regards
Alberto R.
(10-15-2019, 10:00 PM)thanar Wrote: Going the MUXSAN way?
Yes  Big Grin
(10-15-2019, 10:52 PM)Alberto609 Wrote: Ciao I Am interested at yours 48 modules, and i like to pick up directly in Neverland. (Are the module disassembled from the external case, or still assembled?)
Best regards
Alberto R.
Hi Alberto,
You have a PM.
Frank
Bump!
The 24kWh pack is no longer attached to my car so it is available for purchase.
