Balancer/Protection Board
Hi guys,
i want to build a 24V System (7 Packs with 40 18650 cells each) and now i am searching for a balancer/protection solution.
What do you think about this one: https://de.aliexpress.com/item/328792692...4VnVC&mp=1
Thank you!
Works. All is up to what you need and want. Your question is to vague
(10-18-2019, 10:10 AM)daromer Wrote: Works. All is up to what you need and want. Your question is to vague
Thanks, but would you trust such a cheap china product?
I would like to use a 1000W (230V) Inverter ... so the 45A version should be enough.
Trust depends? I would not trust it for my house with 2nd hand cells that i have no knowledge about. I would though use it for an ebike or equal thing or a garage thingy.
1000w nominal is 40++A. I would use an 80A BMS atleast. A 1Kw inverter can easily peak 2x during some seconds.
I would like to build a small hardcase (mobile battery pack) with it. So i think it should be ok (and not so dangerous) to use such a cheap balancer for it.
Ok thank you for your hint ... then i take another one with min. 80A.
Thank you!
