hello need advice and information about 9800mAh cell
I really cant advice on any gear nor China gear as such. I dont have any source in China that is good enough but I havent either done any tests
(10-21-2019, 05:09 PM)stiplanet Wrote: hello Daromère i live in africa buy from china market is easy and good for me ,like chine onlie store
advice me china shop and the quantity i must to buy , and  all accessories i will need thanks
The problem with your questions is that we all have different requirements and expectations of what we won't to achieve from our systems.
Your requirements will be site specific to your needs and as such anything recommend could be vastly under or over sized to meet your requirement.
I would suggest you start out by deciding on what you want from your system i.e. off grid, grid tied, hibrid, do you want to meet all your power needs, supplement an exiting grid supply or emergency backup in the event of a grid failure?
Size your packs to suit your requirements, select equipment based on your needs.
I would recommend a thorough read through the FAQ's and various build threads, to get a better understanding of what's involved.
Oz18650 and Korishan like this post
UK Southwest.
thanks Chuckp thank you for your advice, I will read the different post to see if I can have answers
I need a backup for off grid system
I need 30kwh at the end but I want to start with a small backup of 14 kwh
to undertand how to build and how 18650 work
thanks to all for your the reply
best regard
chuckp likes this post
