Currently I am building a 14s80p 10 kWhDIY powerwall with 1120 used ebike 18650 cells (2200 up to 3600 mAh). As cell holders I am using 8x10 3D printed trays (ABS). The busbars will be made out of6 mm (AWG 10) solid copper wire. The plus pols will be protected with 4 A glass fuses.
With wiring would you recommend?
I am afraid that type A could make problems as no crossequalizationcan occur. But do you think this is needed/important?
The minus pol side will be mirrored as most of us do (e.g.HBPowerwall, ...)
