BMS in LG CHEM ESS modules
Does anyone know a way to talk to these? If not any idea what kind of connection this is? These are the ones battery hookup had a few weeks ago.
Thanks,
Will
If those are the 9.6 khw ones, I just got them. I was told on another forum that the way to communicate with the BMS is by using an RJ48 connector to connect to the CAN H and CAN L inputs on the inverter.
They are the 9.6kwh. There is no RJ48 on them that I can find. There is a pair of 8 pin connector's on the front though. If you have any other info or could PM me a link I would appreciate it.
Thanks,
Will
Ok. Another user from Australia provided me that info in another forum and also sent me a couple of picks. I will check first and also take a look at mine this weekend and then PM you.
w0ss likes this post
FYI - The guy i chatted with had the smaller (6.3kwh i think) version with the rj48 cable connection on the front. I have the larger version like you do and am still trying to figure out how to connect/access the BMS. I will let you know if I get anything figured out.
Ok, thanks for the info. I bought a connector on digikey that I need to verify it fits. If it does. I will just make a converter board to turn it into a JST connector. All this is assuming I can't figure out the BMS
OK Please let me know if you have any success.
no success on the BMS but figured out the connector and pinout. Balance is not the greatest on these if you trust the ISDT BG-8S
Connector is the "MFG : TE Connectivity AMP Connectors / 1318853-2" which cost $5 quantity 1
That's great progress. Thanks for sharing. I haven't found the time to touch mine since mounting them. What inverter are you using?
I have a pair of Sunny Island inverters.
