Experiment: Soldering 18650 = Capacity Fade?
Hey, guys,
I did a test to find out if soldering 18650 cells leads to a loss of capacity or not.
I tested 4 cells and used the following procedure:
1. Each cell measured 4x (capacity). So 16 tests overall
2. 2x soldered, (one solder point) and then again soldered a piece of virtual wire.
3. let it cool down
4. 4x capacity measured.
In my opinion there happens absolutly nothing.
Here are the results (blue is before soldering an red after). The error bars describes the deviation of the 4 tests:
I also documented this on YouTube (german):
There should be no damage whatsoever is properly soldered.
I did write about this some time ago:
https://xaeus.wordpress.com/2014/04/20/s...damage-en/
100kwh-hunter and Korishan like this post
(10-29-2019, 09:49 AM)Overmind Wrote: There should be no damage whatsoever is properly soldered.
Your article just didn't have the proof  Wink
There are a few videos that used thermal cameras to show the process of what happens when soldering. The heat from the iron travels very quickly down the shell of the cell, even in a couple seconds (which about 2-3 seconds is the longest contact should be made). Unfortunately, it's hard to tell what happens on the inside of the cell and what happens chemically.
drbacke: I do appreciate the testing done (haven't yet watched the video at this time). However, I would recommend revisiting those cells in a few months time and see what happens. I would gather that any capacity degradation shouldn't happen in a few hours/days, but over a longer period. Perhaps even do a test where you specifically heat the cell up (with the iron) for longer durations, say 10 seconds or so. Maybe that will have an adverse effect in a few months.
Any time we deal with these types of things, how long is the determining factor of failure.
BatteryMooch and 100kwh-hunter like this post
I'd also be very interested what (if anything) happens to the cells long term. Perhaps do 100x capacity tests over a couple of months using a set of soldered cells vs another set of non-soldered control set?
100kwh-hunter, Korishan, BatteryMooch like this post
Annecdotally, I've soldered all my cells (over 5,000 to date). The actual ah of each pack after soldering them up vs the total of cell tests via OPUS has been within 1% - in other words, any 'immediate' damage is not detectable within looseness of using OPUS etc.
My longest (soldered) pack has been running for 18months with 458 daily charge/discharge cycles with average 35% DOD - and have not detected loss of capacity yet. But again, my measurement info is not that rigorous.
However, so far, I'm not concerned about soldering and plan to continue.
I'm more concerned about 13.6% loss of power due to my inverter efficiency . I've generated 9300kwh but only been able to consume 8,031 due to inverter losses. That's 1,268kwh left on the table - sigh, I definitely have SOCD (Solar Obsessive Compulsive Disorder) to some degree Smile
ajw22, 100kwh-hunter, Korishan like this post
Lol SOCD (Solar Obsessive Compulsive Disorder) Didn't know it was a thing but that being said I have it too. - and Yes I had to steal that
bogptrsn, 100kwh-hunter, ajw22 like this post
(10-29-2019, 12:18 PM)Korishan Wrote: There are a few videos that used thermal cameras to show the process of what happens when soldering. The heat from the iron travels very quickly down the shell of the cell, even in a couple seconds (which about 2-3 seconds is the longest contact should be made). Unfortunately, it's hard to tell what happens on the inside of the cell and what happens chemically.
That would actually be very interesting, unfortunately these special cells are my servants for everything Wink  I'm afraid but these cells won't live for a few months.
In addition, there would be no comparison cells, how is that possible with used ones? So I would have no statement after a few months.
But I also measured the internal resistance (before and after) and could share the results with you. If you're interested in.
However, they are clearly more contradictory, but perhaps this is very interesting.
100kwh-hunter likes this post
@drbacke,
Why don't you get a (ONE)defective ebike battery.
The bms is usually demolishing/ignoring(thus not charging) the first group, but the other two groups are usually very good.
Those two last groups are (mis) treated the same, so consistent results?
Of Course do a ir test on all those cells first.
Then charge and discharge them equally at the same amount and time.
This will give you very consistent and reliable data, in my opinion that is.
(10-29-2019, 06:18 PM)100kwh-hunter Wrote: @drbacke,
I'll admit that's a possibility. To be honest, it's just too expensive for me.
I also think that if you can't see a change in capacity and resistance, then the probability of a change after a few months is relatively low. But maybe there is one.
Another possibility would be to take 4 new and identical cells:
1. Soldering a cell
2. To heat a cell strongly (so that something should happen)
3. And leave one alone.
4. Then to unload them and cut them open and look inside the cells
But what do you think about the measured IR, there is an increase in at least 3/4 cells:
