Crimp Daddy
- Feb 21, 2018
- 973
Does anyone have any experiences or insights to share between these two charging boards?
I'm trying to decide if its worth spending the additional cash on the TP5100.
I do like that the TP5100 has a higher input voltage, being able to use a native 12v supply is the main reason I am looking at this board. Aside from that, not sure if the board does anything special (or better)for single cell charging. The 2s capability isn't of interest to me.
I also plan on changing out the resistors to reduce the charging current.
Important feature would be a pre-charge for low voltage cells. I am getting tired of bump charging with my variable DC supply. Any insight on this specifically?
