100kwh-hunter
Active member
- Mar 2, 2019
- 1,355
Hai all, i am slowly.... moving.... slowly..... into my next phase.
If i understand it right:
I buy one solar charge controller from vectron 100v/50amp
And the solar panels are 32v nominal, 41v 11amp without load.
I can connect 4 groups of 2parallel panels on that charger.(4s2p)
( i have a feeling: i didnt write this down correct?)
So 4 in series with 2 parallel(41v+41v@11 amp) would be max 82v by 44 amp?
The solar charger can handle this.
It is going to be a 48v nominal system.
Or is it better that i connect 3 in parallel (and buy a 150v)or seek for other volt range in panels?
Any advice is appreciated, thanks in advance
