11-03-2019, 09:17 PM
(This post was last modified: 11-03-2019, 09:32 PM by Jonisingt35r. Edited 5 times in total.
Edit Reason: aswes
well i did plan a really good design where the fuses would be protected, as for the correct fuse it could be reaally difficult to fit the correct one as im sure cells characteristics would change a bit i may just fit fuses and see how it runs, i have two motors on the way, i do intend just using the same cells recycled ones only my best ones, will definatly find out what their discharge current is and use that, didnt think about that so thanks, i will use these fuses or simular if i can get a speck sheet, and lay out a small pcb it will be reayy well protected
https://www.aliexpress.com/item/33012231...b201603_52
yes i am going to use a bms, a lot of skateboards just use new cells without a bms, think it would be ok for a while....
i did concider no bms, just thought about balancing it every couple of charges, but that cheap chinese bluetooth one is pretty good
Battery is li iron using 18650s, 14s, 0p, and growing cell so far 300, untesteded.
Bms is a diy open source by stuartpittaway.
No solar yet,
Building wind turbine, 48v im after a 48v motor if anybody has one for sale.
Cells 2000 to 2500ma.
Cells 1500 to 2000ma.
Cells 1000 to 1500ma.
No solar yet,
