Cheap Chinese Active Balancers
Yeah you unlock some capacity but only IF your pack nominal current draw is lower than the balancer can balance. And for most users thats less energy gained than the cost over 10 years IF you look towards that cycling Them that Hard so you need to bottom balance you wear out the cells within a year anyways Smile
Note that you cannot go by Charge capacity because thats higher since they waste some balancing Wink
The canbus based ones would be nice to test
