Android/Raspberry Pi Battery Monitor?
I've been searching all over for a design for a Rasberry Pi or Arduino or Android project that has ability to connect a set of BMS leads (such as Tesla 6s leads + two thermistors) and generate a graphical monitor. (Kind of like the IDST cell monitor)
Does anyone know of a breakout board project like that?
Batrium bms with watchmonudppistener that i built.
Are you any good at writing or at least understanding code? There is an open source BMS controller already for Tesla modules with the OEM BMS boards
https://github.com/collin80/TeslaBMS
Take the output from that board and pass it to NodeRed or Influx/Grafana and you have your dashboard.
If you'd rather go the easier route you can get a SimpBMS or if you want to do nothing with code or wiring get the EVTV controller with a display.
Have you checked out all the Arduino/BMS projects on YouTube? I don't know if any pertain to exactly what you are looking for but I keep running across quite a few of them.
https://www.youtube.com/results?search_q...+bms+18650
