[CLOSED] Cells, batrium, holders, ect, EU from the Netherlands
Selling some stuff.
The big boss is getting a little bit inpatient plus i don't have the time for it.
(main reason is we are closing the pond, we had a visit from a caviar hunter)
ALL cells are above 90% SOH and above 2600mah, tested at 1A charge and discharge.
Origin of the cells, only ebike batts, and some (~20%) from a professional recycler.
Open for offers also.
Those packs are with glass fuses (5Amp)and soldered ready for (ab)use, cells are evenly distributed among packs, for a even amount of power between the packs.
125E a pack = 1750e, all in one go 1350e.
Unsoldered packs, but cells are evenly distributed among packs, for a even amount of power between the packs.
100e a pack = 1400e, all in one go 1000e
535 cells sorted by brand.
100e per pack, 450e for all 535 cells.
300x icr1865026,100x ncr18650pf, 130x lgabmg11865
All cells mentioned above are a minimum of 2600mah (3000mah max) and minimum of 90% SOH, the IR is checkt with the YR1035 and with a max deviation of 10% of factory optimum!
Low mah cells, 2000mah to 2600mah.
420 cells, 200E
Batrium, was playing a little with it, 10 min max 30 min so 14 longmons are tested.
In total 42 longmons and the watchmon 4 incl factory update.
Wm4 new without import tax or other fees is 635E incl 14 longmons.
28 longmons 380E without import tax or other fees!
I don't remember exactly what i payed for all of it to get it into the EU(the Netherlands) but it was way over 1500E
1000e in one go.
The Yr1035,used 25E, incl wooden sorting board if you wish.
52 x 5 (4x20 cells) cell holders.
260 (4x20) holders per 50 15.00E
All in one go 50E
Lug crimping tool plus 100+ lugs plus a lot of clean copper wire (2,5mm2/2,05 diameter) for making busbars.
30e in one go
Tool was 27,- euro, lugs are copper and tin plated 13e per 100 pieces
5amp fuses, 1800 pcs high quality! Not random mistakes or cheap quality.
25e per 1000 pieces, in one go 35e
Soldering station stuff
100w iron plus two new tips (new 50e), 20e
+/- 500 meters silver plated copper wire, 0.8mm thick,  was 80 cents a meter.
Use for soldering the neg side, not as fuse wire!
200e for the whole coil, incl board and iron if you want.
Or a certain amount of wire, minimum 50 meters, per 50 meters
180w tester (from ali) 20e
20 zb2l3 (from ali) 20e with a lot (~50-60ish)of resistors not from ali, 4.1 ohm to 6.8 ohm all 5 watt cement
4 fuse boxes 20 each, 60e in one go.
Some small stuff like tp/tc chargers 2 amp boards.
Open to serious offers as well!
For Dutchies:
Next month i am working in Purmerend, Zaandam, Hoogkarspel, Den Helder, Hoogezand.
So in those areas i can take the stuff with me to hand over after agreement, so without shipping costs or extra fees.
If i have to drive a small piece it would be oke, longer pieces are by the kilometer fee(dutch standards).
In other cases: shipping costs are for the seller
Zvonko000 and Korishan like this post
What a setup! WOW! If someone buys this all they got a full scale setup already on going!
Btw what is a Caviar hunter?
Can you more information on the Batrium so I can make you an offer?
Disregard didn’t read thoroughly of the post
@Daromer,
I already sold 2400 cells in ready to go packs to a friend of mine.
My total was 6000 cells.
A caviar hunter:
Caviar is a somewhat expensive delicacy, eggs from a sturgeon.
Some idiot cut open two of my fish to get the caviar out, they don't survive this procedure.
The fish in my avatar was also harvested, i had this one for over 25 years...
If i find that bastard he will find out what it is to have a marine (Corps) against him.
Thanks for the compliment, and yes, the buyer only have to instal it.
I will replay on all pm's and posts, it will take some time.
Btw i don't give up, i just quit, after closing the pond, our power consumption will be probably 2-3 kw a day
@xyoung347x.
Batrium is a bms system, you can not operate a li ion bank without it.
https://www.batrium.com/collections/dece...n4-longmon.
This is my price, tax and other fees are for buyers account.
I know what caviar is but never heard of someone strealing it like that. Bastard !
ah man, that sux!! I agree, what a bastard! I don't blame you dude if your fist accidentally slipped.
Update: In reservation/probably sold:
14 longmons
1400 unsoldered cells, sorted en divided equally to balance the whole pack(14s).
500+ cells sorted on manufacture.
400+ cells between 2000mah and 2600 mah.
@ Korisan, thanks.
Probably it won't be only my fist, and probably not even by accident.
If this fraze is out of line with the forum rules, please delete it and accept my apologies on forehand.
hbpowerwall likes this post
Update:
Cells in unsoldered packs are gone, incl 535 sorted and my "low" mah cells, with 14 longmons
Probably also sold the solderd packs, still open for decent offers.
Probably also 14 longmons are gone.
Offers for 28 longmons with batrium are first choice and still open.
Best
I am pretty busy the next couple of days, sorry if i don't reply immediately
Update:
Cell holders, fuses, YR and the lugs plus crimping tool are also in reservation/spoken for.
Batrium unit with all the longmons are also reserved
