Tesla module with SimpleBMS settings
Hello
I have 4 Tesla Model S modules. I am going to have a 48V setup.
I am using SimpleBMS to control Victron Inverter and MPPT.
Can anyone help me by reviewing my settings for the BMS?
1 – Over Voltage Setpoint = Overvoltage limit per cell in mV 4200mV
2 – Under Voltage Setpoint = Under-voltage limit per cell in mV 3000mV
3 – Over Temperature Setpoint = Setpoint at which allowed discharge and charge current is reduced to zero 65.00C
4 - Under Temperature Setpoint = Setpoint at which allowed discharge and charge current is reduced to zero -10.00C
5 – Balance Voltage Setpoint = Setpoint of cell voltage in mV at which during charging cells will start balancing. 3.900mV
6 – Balance Voltage Hysteresis = Voltage required to be above the lowest cell to allow balancing of cell in mV 40mV
7 – Battery Capacity = each group of parallel cells monitored per slave capacity in Ah 100
8 – Max Discharge = maximum discharge current in A, transmitted current limit will taper from max current starting at discharge temp to zero at over temperature. 30.00A
9 – discharge voltage limit = used to calculate max discharge setpoint, voltage per cell will get converted to pack level by BMS 3200mV
Hello Seawater, I sent you a PM, best Carel Hassink
pro-LOX, Carel Hassink,
Obdam, Netherlands
26 User(s) read this thread:
daromer (11-10-2019, 06:30 PM), wind0r (11-12-2019, 04:14 PM), OffGridInTheCity (11-11-2019, 12:10 AM), rogeriosom (11-11-2019, 12:34 PM), Overmind (Yesterday, 11:22 AM), Lucan (11-10-2019, 06:23 PM), 100kwh-hunter (11-17-2019, 05:11 PM), xyoung347x (11-17-2019, 04:18 AM), jones1039@yahoo.com (11-11-2019, 03:35 AM), Mubaslat (11-14-2019, 04:32 PM), Seawater (11-10-2019, 08:28 PM), testcrash (11-15-2019, 04:52 AM), stevelectric (11-11-2019, 09:57 PM), camthecam (11-10-2019, 07:48 PM), Korishan (11-10-2019, 07:58 PM), PAF (11-11-2019, 07:38 AM), Batrium (11-15-2019, 04:29 AM), jdeadman (11-11-2019, 03:03 AM), KtB (11-12-2019, 10:40 PM), CarelHassink (11-10-2019, 06:30 PM), HughF (11-15-2019, 04:17 PM), Crimp Daddy (11-11-2019, 04:44 PM), jonyjoe505 (11-10-2019, 04:52 PM), Riplash (11-10-2019, 07:21 PM), Beholder (11-11-2019, 10:16 PM), crash course (11-16-2019, 07:59 PM)
