11-20-2019, 06:36 PM
Data References:
http://www.nkon.nl/sk/k/m36.pdf
Pictures:
Brand: | LG |
Model: | LGDBM361865 (INR18650M36) |
Capacity: | 3440mAh Rated |
Voltage: | 3.63V Nominal |
Charging: | 4.20V Maximum 1000mA Standard 2330mA Maximum |
Discharging: | 2.50V Cutoff 670mA Standard 5000mA Maximum |
Description: | Blue Cell Wrapper White Insulator Ring 18650 Form Factor |
Data References:
Pictures:
!!BLACK FRIDAY SPECIAL!! << SALE STILL ACTIVE
Brand NEW LG 18650 Cells 2600mAh, Only $0.75 Each!!
^ Use discount code "BATTERY" for an additional 10% off!
