TheBatteries
Administrator
- Joined
- Oct 8, 2016
- Messages
- 2,127
Data References:
https://www.omnitron.cz/download/datasheet/NCR-18650PF.pdf
Pictures:
Brand: | Panasonic |
Model: | NCR18650PF |
Capacity: | 2700mAh Rated |
Voltage: | 3.60V Nominal |
Charging: | 4.20V Maximum 1375mA Standard --- mA Maximum |
Discharging: | 2.50V Cutoff 540mA Standard --- mA Maximum |
Description: | Green Cell Wrapper White Insulator Ring 18650 Form Factor |
Data References:
Pictures:
