1S16P PCB BOARD
(12-01-2019, 02:13 PM)emuland-metroman Wrote: each board can draw 50A continuos, 100A burst (1sec)
yes holder cant go over 4A each slot or start heat so 4x16 64A due to holder limit
Then perhaps you need to use these numbers for your rating, not the pcb. Stating that it can do 50A when the weakest link is only 4A is a bit misleading. Yes, I know there are other holders out there, but they don't have that much better performance.
4x16?? Is each PCB just 16 cells in series, or are they 64 cells(16s4p)? I'm getting confused as to what you are actually trying to accomplish here. Please make a posting of your available information in non-conflicting terms and much clearer wording.
1 slot 4 A
16 slot per pcb means 16 x 4 total amps from holders.
(every holder has 4 bay, every bay can do 4Amps)
pcb traces can handle 50A contiunuos
so holders can give 64A without heat, pcb can handle 50A with delta T of 20° then start to "heat too much".
i think i've done my homework.
Ohhh, these are 16p, not 16s. got it.
ok, i was thinking to have write wrong somewhere.
(12-01-2019, 01:52 PM)Korishan Wrote: So how many amps is this thing supposed to be able to handle? Since this is a 16s1p board, each cell holder can only handle a max of around 5A, and even that will generate heat. So considering these are only 1p, that means no where near a sustained 5A load.
Again, I say this approach is expensive.
Just the PCB's on JLC will cost a lot. Can you provide the gerber so we can get a cost estimate?
gerber isn t free at the moment, we are developing a multiple sistem
pcb
monitoring system
bms
will go on kickstarter soon i wish
