TheBatteries
Administrator
- Oct 8, 2016
- 2,127
Data References:
http://www.eveargentina.com.ar/gallery/icr18650 26v-s03-lf.pdf
Pictures:
Brand: | EVE |
Model: | ICR18650-26V |
Capacity: | 2550mAh Rated |
Voltage: | 3.60V Nominal |
Charging: | 4.20V Maximum 1275mA Standard 2550mA Maximum |
Discharging: | 2.50V Cutoff 1275mA Standard 7650mA Maximum |
Description: | Blue Cell Wrapper White Insulator Ring 18650 Form Factor |
Data References:
Pictures:
