robertjpjr
- Dec 12, 2019
- 4
First off, New user. This answer may be posted somewhere else, but at this point I have watched tons of videos, and searched that my head hurts.
I can't seem to post a jpg or png photo. New user restriction? Nevertheless..
My issue:
How do I charge a 3s8p 18650 cell pack with BMS wired into it? I assembled my pack, wired up the BMS listed below, but am confused as to the best way to charge my pack. I see people charging using laptop chargers, etc. Just supplying voltage to the BMS circuit.I have RC chargers. My most powerful being the Reaktor 300w 20A
Can I use this charger to charge my pack with it's built in BMS? The charger balances the cells as it charges. Does this "Double balancing" have any ill effects?
Also, would I need to wire balance leads to get the charger to initiate? Most chargers don't allow charging multi cell packs without said balance port in use.
I do have many laptop chargers at my disposal, but those are usually low amperage chargers. With the RC charger I could charge at any Amp up to 20a.
I intend on powering an AC plug to plug devices into. I am using a cheap Banggood 40a 3s BMS.
To whomever reads this, thank you! I hope I can get some clarity on the best way to charge 18650 packs, as this is my first. If I have left out any pertinent info, please let me know.
Mods: If I have violated any rules with links, or photo embedding, this is unintended.
My issue:
