w0ss semi DIY powerwall V2
#81
to add to the confusion, i DO NOT have voltage through my case...@wOss did both of your cases show voltage?
#82
So far, I have only checked one of my three modules after seeing that post a few pages back. I did not have continuity between the negative terminal and the case suggesting to me that the case was not bonded to the negative. I still need to open the modules again and inspect them in more detail. When I do, I'll take some photos.
I received my boards the other day as well as all the parts. I started soldering them, but have yet to finish. I definitely appreciate the board and design, thanks again w0ss. Once I have the boards completed and installed, I'm looking forward to checking the cell voltages to make sure everything looks okay. Also received my Watchmon and MM8's. It was pricey, but I think it will be worth the cost.
(06-12-2020, 04:32 PM)vegburner Wrote: @hydro
Would this be an option at the battery?  https://www.delcity.net/store/Del-City-M...3.h_195738  ----Your terminal fuses look nice and clean.
I considered a circuit breaker, but seems like a lot of folks go with fuses.  No sure if there is a reason for that, I haven't looked into the breaker specs. The costs come out to be about the same from what I can tell.
Like many other folks, I will be using a shunt-trip breaker as my overall battery disconnect, but am also placing a main fuse in that line as well.  I guess breakers could work on each of the module strings, but like I said... based on what I've seen, fuses seem to be the common method for protection.
I agree, these terminal fuses are nice and clean.  I measured the terminals on the modules and I believe these terminal fuses will fit.  the holes on the terminal fuses are plenty big compared to the terminal posts on the modules. The width of the terminal fuse (about ~3/4" seems to fit through the opening on the module (~1") such that the terminal cover can be closed and no modification should be needed.  I have seen references to these fuses being used on lithium batteries, but have not reliably confirmed that yet.
#83
A few things...
I did NOT have continuity between the case and the terminals.  I only bought one cell.  Regretting that now that it seems these units turned out to be pretty good.  Paid all that shipping cost for one item...d'oh
When I hooked up a wire harness for BattGo BG-8S (max 8 cell) monitoring, for the first set of 7S (cells 1-7) the black wire went to Pin 2 (Cell1 neg) of the LG connector.  Straightforward enough.  But for the second set of 7S (cells 8-14), the black wire went to Pin8 (Cell8 neg) to get proper readings for the latter half of the cells.  Kind of confusing, until I recalled what w0ss mentioned earlier about the original monitoring board being split into 2 parts.
And some questions:
Did anyone see any temperature probe leads when they opened the battery cases?
Did you see where the other wires go that come from the orange harness loom...the mystery pins (1,7,13,14,18,19,20,24)?
w0ss likes this post
#84
(06-18-2020, 03:16 AM)Sojourner Wrote: A few things...
And some questions:
I am going to take mine apart again and try to figure out why I have connectivity. I will look for a temperature probe but I assume they have them on a few of the leads.
Sojourner likes this post
#85
I checked my other modules and none had continuity between the case and neg terminal.
I also finished soldering my boards and installed them to check the cell voltages. Everything looks good. The cells provided consistent voltages and appear to be well balanced.
One thing I noticed was that when I attempted to re-install the black, plastic front cover, the U50 and U51 terminals on the board were preventing the cover from fitting properly. I noticed a 1/8 or so gap indicating the terminals are sitting a bit higher relative to the components on the original board. I'm not sure if anyone else has encountered this. I used these terminals from amazon: https://www.amazon.com/gp/product/B00FZL...UTF8&psc=1
Maybe they are a little taller than other available terminals, not sure. Its not a big deal, I'll just have to modify the cover at some point to make it fit properly... but figured I'd mention it in case others are using the same terminals.
#86
I noticed it was a tight fit as well. I have been trying to think of another way to connect the balance wires. one thought I had was to just solder the wire right to the board.
#87
Hey Murr, i can't send you a pm back, says your pms are disabled. i have 3 spare board if you are in need...
#88
Thanks vegburner. I'll pm you my email
#89
Anyone find a data sheet for the LGX JH3 cell ?
Even the max discharge and max charge amps for the battery packs?
later floyd
