10kW Hybrid Inverters
#31
Daniel a question for you...
With the MPP inverter, what happens if you use more than 3.33kW on 1 phase, does it shut down the whole inverter?
Follow my Powerwall journey here:
Youtube: https://www.youtube.com/channel/UCjXT8KJnEzo-DJHFRR1W8jg
Building the following:
20kWh Powerwall
8kW Solar
30kW Heating system
#32
It complains and beeps like crazy. IF you go over somewhere between 3.6-4kw it switches to grid. Above 4... It djurs down Making output 0. Though you can push 5kw for 1 second but thats max.
All mpp producs is max rating mentioned. Victron as example mention nominal. So a 6kw victron is actually better than a 10kw mpp Smile kind of
The Kilowatt Challenge likes this post
