Parallel connection of MPT7210A, is it possible ?
This is a silly question but I can't find the answer anywhere.
I have a panel of 160w 12v and another of 330w 24v.
One of the panels connected it to the first MPT7210A and the other to the second MPT7210A. Both MPT7210A are programmed in the same way. Is it possible to connect them in parallel to charge a 24V battery?
Sorry for my English
You can have as many chargers as you want connected to same battery S Long as you make sure they dont fight Each other.
Set One of Them 0.1v higher than the rest
As said above, any number of power sources can be connected in parallel. The important part is making sure the settings are all consistent.
