So as im building a big pack, 20KwH, and its my first pack, for our new house, i was originally planning on storing the batteries in the garage. However, im not sure if the insurance will cover a fire started by an enormous battery which is home made.
Then i thought, well i will build a outside shed, big enough for batteries and inverters, but i recently learned that if the batteries gets cold, and charged at the same time, i will ruin them?
Im from denmark, so in the winter, it gets cold. Maybe minus 10, but mostly around 0 degrees. I know the batteries AND the inverters will generate heat, but im not sure if the shed will be warm enough, it depends ofcoourse on the sun.
So what do you guys think? Where do you have your batteries? Did you ask the insurance company?
Thanks, and best regards from Denmark.
