SimpBMS Setup for Tesla battery modules in parallel
Hi Everyone
Bringing my SimpBMS configuration on line and having a couple of problems.
My target environment is a bus conversion motor home with:
1. Victron Color control head
2. Victron Solar charge controllers
3. Singineer Inverter/Charger 6KW Tesla model APC6024DT
4. Two Tesla Model S modules connected in parallel.
5. SimpBMS for Tesla
My SimpBMS configuration:
1. SimpBMS 2.3 board
2. NEXTION display
3. LEM CURRENT Sensor CAB300-C/SP2 (Read documentation, VCC is connected to 12V for this sensor).
4. OMRON CONTACTOR G9EA-3-CA-M2 (not using at the moment.)
All the above SimpBMS items were purchased directly from secondlife-evbatteries
My current status:
1. NEXTION display works well
2. Connected a terminal emulator to Teensy 3.2 compute module and see output
3. It is reporting that voltage as 45.6 as if the modules are in series.
Modules: 2 Cells: 12 Strings: 1  Voltage: 45.615V  Avg Cell Voltage: 3.801V  Low Cell Voltage: 3.799V  High Cell Voltage: 3.803V D
elta Voltage: 4mV  Avg Temp: 18.754C
Module #1  22.81V  Cell0: 3.80V  Cell1: 3.80V  Cell2: 3.80V  Cell3: 3.80V  Cell4: 3.80V  Cell5: 3.80V  Neg Term Temp: 18.86C
Pos Term Temp: 18.52C
Module #2  22.81V  Cell6: 3.80V  Cell7: 3.80V  Cell8: 3.80V  Cell9: 3.80V  Cell10: 3.80V  Cell11: 3.80V  Neg Term Temp: 19.03C
Pos Term Temp: 18.61C
CANbus  0.00mA  67% SOC 67000.00mAh
4. I entered the setup menu and then debug and set the ESS mode to 1
5. I went back to the setup menu and selected "c" for current sensor calibration
6. I configured the sensor type and for LEM CAB series
Current Sensor Calibration Menu
c - To calibrate sensor offset
s - Current Sensor Type :  Canbus Current Sensor
1 - invert current :0
2 - Pure Voltage based SOC :0
3 - Current Multiplication :1
7 -Can Current Sensor : LEM CAB series
q - Go back to menu
Calibrating Current Offset ::::: ....................5 current offset 1 calibrated
Calibrating Current Offset ::::: ....................5 current offset 2 calibrated
7. I then went to the Battery Settings Menu with the "b" letter command
r - Reset AH counter
f - Reset to Coded Settings
q - Go back to menu
1 - Cell Over Voltage Setpoint: 4200mV
2 - Cell Under Voltage Setpoint: 3000mV
3 - Over Temperature Setpoint: 65.00C
4 - Under Temperature Setpoint: -10.00C
5 - Cell Balance Voltage Setpoint: 3900mV
6 - Balance Voltage Hystersis: 40mV
7 - Ah Battery Capacity: 100Ah
8 - Pack Max Discharge: 30.00A
9 - Cell Discharge Voltage Limit Setpoint: 3200mV
0 - Slave strings in parallel: 1
a - Cells in Series per String: 12
b - setpoint 1: 3100mV
c - SOC setpoint 1:10%
d - setpoint 2: 4100mV
e - SOC setpoint 2: 90%
g - Storage Setpoint: 3800mV
h - Discharge Current Taper Offset: 300mV
j - Discharge Current Temperature Derate : 40.00C
I then attempted to use the command characters "0" or "a" to try and alter the values to setup for modules in parallel and got no response to the requests.
So at this point I have the following:
1. Reported pack voltage is incorrect
2. Charge or Discharge current is not being shown on the NEXTION display.
Thanks
Fred
Hello Fred,
when changing values, confirm with Q, Q to get back to main screen, this way it is written to memory
You can alter more than 1 value in same sub menu, but do need to confirm with Q,Q>>main screen,
perhaps try it.
1 caveat about the Omron contactor not suited for low voltage high current storage battery, you will weld the contacts
best Carel
pro-LOX, Carel Hassink,
Obdam, Netherlands
Hi Carel
OK, I write terminal emulators for a living and did a download of Termite and used it. I see that this emulator uses a separate command line input box and sends that output as a string of characters, not individually as you type them on the keyboard.
So a bad case of RTFM and unnecessary hubris on my part, thanks for the assistance in this problem.
My understanding is that relays can handle high amperage at lower voltage. The Omeron contactor is rated at 60 amps at 400V and 100 amps at 120V. Here's a little blurb on the subject that I found online:
Relay Ratings and Limits
This does not necessarily tell you what the limits of the relay are. For instance, a 5 Amp relay rated at 125VAC can also switch 2.5 Amps at 250VAC. Similarly, a 5 Amp relay rated at 24VDC can switch 2.5 Amps at 48VDC, or even 10 Amps at 12VDC.
Choosing a Proper Relay Amperage
I would think it is the amount of energy being switch on and off. In my case I am ganging all three sections of the relay in parallel and on/off events are going to be rare in ESS mode, just when the battery needs to be protected.
Any thoughts on how to diagnose the LEM current sensor problem?
Again thanks for your assistance.
Fred
PS. With both emulators there seems to be problem in that you can only attach serially one time for each power cycle (at least under windows 10).
Fred,
I don't know if aware of github.com/tomdebree,
check for SIMPbms manual, and latest firmware.
best regards
Carel
Obdam, Netherlands
(01-06-2020, 05:58 PM)CarelHassink Wrote: Fred,
best regards
Carel
OK, I had a bit of a learning curve to bring this up especially the confusion of wiring up the LEM CURRENT Sensor CAB300-C/SP2, as there is a tendency to follow diagrams verses reading detail in the manual.
The diagram shows connecting the current sensor to J2, where as this sensor requires running wires to connectors J4 and J5.
My final step will be connecting the contactor and then I will have full functionality.
Fred,
J2 is for analogue shunt connection
J4/J5 for a can-bus shunt like LEM CAB300/500
as per manual,
Glad to hear I could be of help,
best of succes with your build.
regards, Carel Hassink
Obdam, Netherlands
