Maniac_Powerwall
Member
- Joined
- Dec 20, 2018
- Messages
- 214
I just read in the manual that you may not ground solar panels connected to the PIP. Is that right or am I missing something?
From the manual:
WARNING:
Because this inverter is non isolated, are accepted: single crystalline, poly crystalline with class
A rated and CIGS modules. To avoid any malfunctions, do not connect any PV modules with possible current
leakage to the inverter. For example, grounded PV modules will cause current leakage to the inverter. When
using CIGS modules, please be sure NO grounding connection.
CAUTION:
Its requested to use PV junction box with surge protec tion. Otherwise, it will cause damage on
inverter when lightning occurs on PV modules.
Thanks again for the help in advance.
From the manual:
WARNING:
CAUTION:
