Today I received my Victron Multiplus II GX 48/3000 and wanted to share some photosfor anyone who is interested.
I have it connected to 28xNissan Leaf (ENV200)Generation 1 modules connected in 14s4p layout using Batrium Watchmon 4 BMS with Leafmon's
Enjoy
Did you know, that you can extend the victron with eltek powerpack 2 in order to increase charge current by 2000W. Victron controls the eltek via can bus directly...
Its a quite cheap and comfy way...
Ill go same route shortly! Victron multiplus 2 gx seems great!
Regards
Karl
Carel sorry, i brought you on the wrong path. Eltek can be controlled by batrium, not by victron directly. Some time ago i was considering using batrium but dropped the idea.
A raspberry with can-shield can do the job but not out of the box though...
I will most probably go with more than one victron.
Maybe i chose a fronius for pv and one mpII gx. On top of that 2 or 3 eltek controlled via my homeautomation system when sufficent solar power is available. 2x2kw from eltek and 2,5kw from victron should give a nice charge.
And when the sun is shining my tesla (shortly to be ordered) can be charged with full pv power...
