Heaters
Hahah yup!
Interesting that it was the greys that went thermal. Usually it's just the Sanyo's.
I watched your 1st video. I think you meant to say "air to air heat pump", not "inverter". They're very good at heating the ceiling while leaving the space we inhabit cool. Try using a IR temperature gun (eg. https://www.amazon.com/dp/B00837ZGRY ) to find hot spots and cool spots in the rooms. If there is a large temperature difference, use a circulator fan (eg. https://www.amazon.com/dp/B004XZDCQW ) to move the cool air up and force warm air down. I like to use the larger ones on the slowest settings for quiet 24/7 operation.
It seems counter-intuitive, but it makes a huge difference both in comfort and energy savings. I've now lowered my thermostats down to 18C, and it's just perfect!
Korishan said:
Hahah yup!
I thought the Sanyo's bypass the thermal stage and jump straight toBOOOOOM!!!! :D
Hey thanks :)Do you know, I was looking at a thermal camera just yesterday!
I totally agreewith your idea regarding the fan. Last year we bought one of those log burner fans that requires no battery, it uses the heat differential to drive the motor - wow, they're awesome and really do work! Our air to air heat pump (often called an inverter over here) broke last week anyway so this sh@t just got real!! LOL!
Thanks for the support on the channel, it's going to take a long time to build an audience but I'm enjoying the sharing so far and the next 3 videos will be uploading over the next 2 weeks.
