Chablism said:Thanks I had not seen any Jehu boards that had holders on both sides of PCB
Also electrical connectors look different.
Is it possible someone developed a similar but improved design?
Maybe I just have old info
mike said:So yes, I'd bet on those being and improved design
Korishan said:mike said:So yes, I'd bet on those being and improved design
To be fair, Jehu released the files before they were really tested and ready for prime time. Rev0 did the initial design mockup and began testing the boards, several vids of the tests area available. Then Jehu just jumped the gun and released them without the test results.
CrimpDaddy said:I like the older v1.1design, and even the older Jehu/Rev0 boards were fine...
mike said:CrimpDaddy said:I like the older v1.1design, and even the older Jehu/Rev0 boards were fine...
So how did you solve the problem I mentioned above where a BMS fuse link could blow and you would never know, thus allowing that cell to operate without the BMS?
