Batrium watchmon4 and leafmon troubles
I have a watchmon4 setup with 14 Leafmon. Working great for over a year. resently i temporary disconnected the charge inverter and solar controller cable from the battery, and reconnected a few days later. Now my SOC hovers at 95 to 100% all day and night and the coulomb counter does not reset to zero at midnight, so now it accumulates charge/discharge . All else looks fine. Did i somehow short the shunt. It does flash red and green like normal. Any ideas as to what i can do, or just replace the shunt. Any input will be appreciated.
System status information
Device Time              Startup                  Ambient  Supply
1/23/2020  9:28:16 AM    1/21/2020  8:36:38 AM      34ºC  55.01v
Versions  Hardware      Firmware      Software        SerialNo
          4.2          4.10          2.0.12          272030448
OpStatus                  AuthMode                  CMU Mode
Charging                  Default                  Normal
SysFaults:  Nil
Live status information
                  Min @ ID      Max @ ID      Avg    Repeat
CellVolt        3.88v @ 14    3.90v @  3    3.89v      6700
CellTemp          24ºC@  1      24ºC@  1      24ºC
BypassAmp        0.00A @  0    0.00A @  0
BypassTemp        23ºC@  1      24ºC@  3
BypSession      84.1mAh@  1  855.6mAh@  7
                Total Overdue  +Final  +Initial  InBypass
NumOfCells        14      0      0        0        0
                SoC%    Temp    Volt      Amp
Shunt          100.0%    43ºC    54.45v    32.05A
                  ToEmpty    ToFull
Nom Capacity      250.114    -0.114
Est Duration        17:04      00:01
Recent Consume      0.000    27.503
Expansion board
Input Run/Idle      = off
Input Charge/Normal = off
Critical logic
control BattOK state
status  OK
Charging logic
control ON state
Idle Bypass: off
status  BypassSessionLo,
Discharging logic
control ON state
status  OK
Thermal Heating Logic
control OFF state
status  OK
Thermal Cooling Logic
control OFF state
status  OK
Remote Logic
        ActV    ActA    TgtV    TgtA  state
Charge  0.00v  0.00A  58.10v 370.40A  ON state
Dischg  0.00v  0.00A  47.60v 400.00A  ON state
Daily Session information
                  Min      Max
CellVolt          3.67      4.13
Thermal            22        35
ShuntSoc          49.5    101.5
ShuntVolt        0.00    57.39
SupplyVolt      24.18    61.52
Critical Events      8
                Charge    Dischg
ShuntPeak        78.54    56.85
Cumulative    837.373  934.931
Banding(hr)  A    B    C    D    E    F    G    H
SoC%      21.3  0.1  6.6  11.0  12.5  0.0  0.0  0.0
Thermal    0.0  0.0  0.0  0.0  25.5  0.0  0.0  0.4
Cell Node information
  ID  Bypass Initial            Session    Amp    MinV    MaxV    MaxT  BypT  HiT  HiBypT LoV    HiV    BypV    BypA  DatEr Reset  CalV RepCV Serial    HwVers
  1                              84.1 mAh  0.00A  3.89v  3.89v  24°C  23°C  55°C  75°C  2.90v  4.20v  4.10v  1.94A    65    2    9  250  284860786  HW14.1 FW2.2 BL2.0
  2                            121.4 mAh  0.00A  3.89v  3.89v  24°C  23°C  55°C  75°C  2.90v  4.20v  4.10v  1.94A    6    3    6  250  284860787  HW14.1 FW2.2 BL2.0
  3                            138.1 mAh  0.00A  3.89v  3.90v  24°C  24°C  55°C  75°C  2.90v  4.20v  4.10v  1.94A  155    4    7  250  286468120  HW14.1 FW2.2 BL2.0
  4                            160.0 mAh  0.00A  3.90v  3.90v  24°C  23°C  55°C  75°C  2.90v  4.20v  4.10v  1.94A    12    5    8  250  284861630  HW14.1 FW2.2 BL2.0
  5                            108.7 mAh  0.00A  3.89v  3.90v  24°C  23°C  55°C  75°C  2.90v  4.20v  4.10v  1.94A  156    6    9  250  286469152  HW14.1 FW2.2 BL2.0
  6                            126.6 mAh  0.00A  3.89v  3.90v  24°C  23°C  55°C  75°C  2.90v  4.20v  4.10v  1.94A  173    7    4  250  286469140  HW14.1 FW2.2 BL2.0
  7                            855.6 mAh  0.00A  3.90v  3.90v  24°C  23°C  55°C  75°C  2.90v  4.20v  4.10v  1.94A    4    8    9  250  284861463  HW14.1 FW2.2 BL2.0
  8                            747.6 mAh  0.00A  3.90v  3.90v  24°C  23°C  55°C  75°C  2.90v  4.20v  4.10v  1.94A    12    9    8  250  284861464  HW14.1 FW2.2 BL2.0
  9                            763.4 mAh  0.00A  3.90v  3.90v  24°C  23°C  55°C  75°C  2.90v  4.20v  4.10v  1.94A    6    10    7  250  286469497  HW14.1 FW2.2 BL2.0
  10                            609.9 mAh  0.00A  3.89v  3.89v  24°C  23°C  55°C  75°C  2.90v  4.20v  4.10v  1.94A    12    11    6  250  286469504  HW14.1 FW2.2 BL2.0
  11                            478.2 mAh  0.00A  3.89v  3.89v  24°C  24°C  55°C  75°C  2.90v  4.20v  4.10v  1.94A    4    12    8  250  286468762  HW14.1 FW2.2 BL2.0
  12                            476.3 mAh  0.00A  3.89v  3.89v  24°C  24°C  55°C  75°C  2.90v  4.20v  4.10v  1.94A    68    13    7  250  286468781  HW14.1 FW2.2 BL2.0
  13                            156.2 mAh  0.00A  3.89v  3.89v  24°C  23°C  55°C  75°C  2.90v  4.20v  4.10v  1.94A    4    14    8  250  286467333  HW14.1 FW2.2 BL2.0
  14                            149.9 mAh  0.00A  3.88v  3.89v  24°C  23°C  55°C  75°C  2.90v  4.20v  4.10v  1.94A    5    15    8  250  286466251  HW14.1 FW2.2 BL2.0
I have a similar issue - using leafs.. I have a total of 168 Gen2 modules in a 48v pack
When my pack was smaller (42 modules) and I was cycling daily it was fine but once I increased my pack size to 80+kwh - its all out of whack. I'm thinking because I now only do a full charge / discharge cycle every 4 days vs daily
My SOC readings have since been very unreliable compared to battery voltage
I'm new to using Batrium but maybe try this the next time you're top balancing: Menu --> Hardware --> Shunt --> Edit --> Metrics --> Full --> Ok --> Save.
(01-24-2020, 02:45 AM)Shade Wrote: I'm new to using Batrium but maybe try this the next time you're top balancing: Menu --> Hardware --> Shunt --> Edit --> Metrics --> Full --> Ok --> Save.
I got the SOC working again, by unplugging the power to the watchmon4 and the shunt and reconnecting. There is still two noticable problems, one is with the Charge Kwh and Dischage Kwh displayed on the software, it is not resetting at midnight to zero. as of today i have a total of 106.3 kw of charge and 102.5 kw of discharge. Maxine suggested I try doing the sync time reset at Midnight but this did not work, and my historical data ends on Jan 15th, and nothing is being recorded after that date.  The second issue i noticed is displayed in the snapshot report.
Snapshot report prior to me Messing things up.
Daily Session information Normal operation
                  Min      Max
CellVolt          3.92      3.95
Thermal            23        23
ShuntSoc          50.0      50.0
ShuntVolt        54.97    54.97
SupplyVolt      55.52    58.06
Critical Events      0
Critical logic
status  OK
Critical logic
status  OK
Charging logic
control ON state
Idle Bypass: off
status  OK
Discharging logic
control ON state
status  OK
After me messing things up Daily Session information
                  Min      Max
CellVolt          3.42      4.13
Thermal            22        35
ShuntSoc          34.5    101.5
ShuntVolt        0.00    57.48
Critical Events    10
Critical logic
control OFF state
status  LowShuntVolt, LowIdleShuntVolt,
Charging logic
control OFF state
Idle Bypass: off
status  BypassComplete, TempRelief, BypassSessionLo, PauseSupplVolt, LimitedShuntVolt, PauseShuntSoC,
Discharging logic
control ON state
status  LowShuntVolt, PauseShuntVolt,
So the low shuntvolt is puzzling. So i suspect that i may have somehow corrupted the electronics in the shunt by not powering down the watchmon4 and the shunt during the time i was disconnecting inverter and solar controller (shutdown and not energized).
(01-23-2020, 08:51 PM)farmerjohn Wrote: I have a similar issue - using leafs..  I have a total of 168 Gen2 modules in a 48v pack
I think you should be top balancing to 4.10v daily. This is how i normally operate.
