Batrium Watchmon4 in Node Red
For anyone using the ISO made by @daromer and wanting to try this you have to disable the Batrium service first because it uses the same listening port.
To do this go to webmin: https://127.0.0.1:10000/ then System and Bootup and Shutdown and make sure the Batrium service is turned off.
Then turn off node-red: with node-red-stop
Then edit the following file so it looks like this: /root/.node-red/settings.js
functionGlobalContext: {
  binary_parser:require('binary-parser').Parser
EDIT: Then we have to install the module like this:
pi@grafpi /energy-logger/solar-sis/example/PCM60x $ sudo su
root@grafpi:/energy-logger/solar-sis/example/PCM60x# cd /root/.node-red
root@grafpi:~/.node-red/node_modules# npm i binary-parser
Then start up node-red again with: node-red-start
I'm having the same problem as @mbrunton though, i can display all the info except for the bar chart. I'll report back if i can get it working.
(01-31-2020, 09:21 PM)Bloater Wrote: Anyway - happy to answer questions if I can
Cheers all
Tim
(06-12-2020, 03:09 PM)Cell-King Wrote: I'm having the same problem as @mbrunton though, i can display all the info except for the bar chart. I'll report back if i can get it working.
Great stuff Tim and Cell-King.
Got it working with Cell-Kings info on the settings.js edit.
Changed the color and all is good.
Hi Wolf, Could you explain how you got the bar chart working in a little bit more detail please? I have seven cells in my pack, I can display the cell voltages but I can't display them on the graph, I'm sending the chart_ui the following array:
msg.payload : array[1]
array[1]
0: object
labels: array[7]
0: "1"
1: "2"
2: "3"
3: "4"
4: "5"
5: "6"
6: "7"
data: array[7]
0: 3.88
1: 3.87
2: 3.88
3: 3.89
4: 3.88
5: 3.88
6: 3.88
series: array[1]
0: "Cells"
(06-16-2020, 06:19 PM)Cell-King Wrote: Hi Wolf, Could you explain how you got the bar chart working in a little bit more detail please? I have seven cells in my pack, I can display the cell voltages but I can't display them on the graph, I'm sending the chart_ui the following............
Make sure you have the y-axis min and max settings.
If you have the min max settings and it still doesn't work I can send you the flow as I just created the barchart in seconds and it works just fine.
Thanks for that, yes I have the min and max set as you describe but I still can't get it to work. Does your "Get the set of saved global variables" look like the following?
var ONE = Number(global.get('ONE')) || 0;
var TWO = Number(global.get('TWO')) || 0;
var THREE = Number(global.get('THREE')) || 0;
var FOUR = Number(global.get('FOUR')) || 0;
var FIVE = Number(global.get('FIVE')) || 0;
var SIX = Number(global.get('SIX')) || 0;
var SEVEN = Number(global.get('SEVEN')) || 0;
var m = {};
m.series = ["A", "B", "C"];
m.data = [ONE, TWO, THREE, FOUR, FIVE, SIX, SEVEN];
m.labels = [""];
return {payload:[m],topic:msg.topic};
I've been playing around with it so yours might look slightly different. Yes, if you could paste your flow somewhere that would be great.
Yea mine looks a bit different.
M.label and m.series are not right in yours I believe.
Here you go.
Code:
var ONE = global.get('ONE') || 0;
var TWO = global.get('TWO') || 0;
var THREE = global.get('THREE') || 0;
var FOUR = global.get('FOUR') || 0;
var FIVE = global.get('FIVE') || 0;
var SIX = global.get('SIX') || 0;
var SEVEN = global.get('SEVEN') || 0;
var m = {};
m.labels = ['1', '2', '3', '4', '5', '6', '7'];
m.data = [[ONE, TWO, THREE, FOUR, FIVE, SIX, SEVEN]];
m.series = ['Cell'];
Here is the flow
Code:
[{"id":"e7cd0e18.4f55b","type":"function","z":"a60793ee.ec643","name":"7Cell","func":"\nvar ONE = global.get('ONE') || 0;\nvar TWO = global.get('TWO') || 0;\nvar THREE = global.get('THREE') || 0;\nvar FOUR = global.get('FOUR') || 0;\nvar FIVE = global.get('FIVE') || 0;\nvar SIX = global.get('SIX') || 0;\nvar SEVEN = global.get('SEVEN') || 0;\n\n\n\n\nvar m = {};\nm.labels = ['1', '2', '3', '4', '5', '6', '7'];\nm.data = [[ONE, TWO, THREE, FOUR, FIVE, SIX, SEVEN]];\nm.series = ['Cell'];\nreturn {payload:[m],topic:msg.topic};","outputs":1,"noerr":0,"x":1180,"y":120,"wires":[["bbffd6bc.05b508"]]}]
Thanks for that, still no luck. I even copied your function over to my existing flow to see if it was a bug with the existing one. I wonder if it's to do with dependencies somewhere else.
(06-16-2020, 07:11 PM)Cell-King Wrote: Thanks for that, still no luck. I even copied your function over to my existing flow to see if it was a bug with the existing one. I wonder if it's to do with dependencies somewhere else.
Whats your debug msg.payload look like?
It seems exactly the same!
Hmmm.
The only thing I can think of is that there is a conflict with one of the palettes.
Do you have more than one ui_chart installed?
