bms at every single cell
bms at every single cell with this bms (
1S 12A 3.7V Lithium Li-ion Battery Protection Balance Board 18650 6 mos )...
i want your opinions . thank you
Change the link please. You need to login to view that ..
https://www.ebay.com/itm/383383797004
No. Use proper bms. Above is for single cell useage
(02-22-2020, 11:28 AM)daromer Wrote: No.  Use proper bms. Above is for single cell useage
explain  ' no ' please
i mean at every cell.... for example ... if i have to use 80 cells ... i use 80 1s mbs
(02-22-2020, 09:48 AM)paraskevas Wrote: bms at every single cell with this bms (
I don't really get the application case of this for the price. It seems to operate on a single cell - I don't see any coordination with other cells in series - e.g. "Balance Board" in the product listing title seems out of place since you don't balance a single 18650 cell.
Because its made for 1s. You should have for 14s IF thats what you go for.
You would need 1400 of above for 14s80p.... Cheaper and better to get a proper system
i just order .... 120 bms boards ....from ebay.... 1s ...6mos 15ampere...........lets see if i am corect . Smile
If you plan running 120p then sure.. But not for anything else. A 1s bms cannot sense overal package voltage or current. And therefore you will get cascading strange effects.
Its also just expensive doing so.
Im sorry but I only see it as a waste of time and money.
15A is also to much for 1 cell... It should be 2A or something
Why did you ask for advice and still you did not follow the advice?
paraskevas likes this post
(02-27-2020, 08:41 AM)daromer Wrote: If you plan running 120p then sure.. But not for anything else. A 1s bms cannot sense overal package voltage or current. And therefore you will get cascading strange effects.
 it is not for power wall.....iit is for ebike .... i like to experiment . Smile . thank you for your advice
