35mm or 50mm cable?
for that Victron inverter, the manual says 70mm2 for 0-5m cable run, see manual page 9
It's so it performs under surge overloads, etc.
re the pre-charge, I've got 2x 10W 4.7 ohms resistors in parallel - via a 10A DC breaker they feed:
1x Victron Multiplus 1 48V/5000kVA inverter (like yours)
3x Victron 150/60 MPPT charge controllers
I have other in-rush devices for the electronics (each 48V connected device has one):
eg Batrium, 48 to 12V 300W PSU, 48 to 20 V 50W PSU (for laptop)
https://au.element14.com/epcos/b57237s02...5-00001622
if you ask you most likely have the money and then you really dont have to ask. Go for 50mm2 and you save energy long term and sleep better Big Grin
Hmm.. the manual does recommend 70mm. Thanks for pointing that out.
A 5kW unit can pull 8-10Kw and thats what you should design for.
Same goes to fusing. Follow recommended. And THEN you build the battery pack to support that current needed in max conditions.
Ibiza likes this post
If the 50 sq mm lugs are very expensive, You could always go for 2 times 35 sq. 35 sq mm lugs are reasonable, and so is 35 sq wire.
ChrisD
FYI
Simple ampacity app
http://www.gtsparkplugs.com/WireSizeCalc.html
Jim
