Why are 12v lifepo4's cheaper than individual cells? What's the catch?
3.2 x 123ah x 8 gives you ~3kwh = 1100 + postage
12.8 x 100ah x4 gives you ~ 5kwh = 2000 ish
A youtube channel "DIY Solar Power with Will Prowse" if full of recent videos on tear-downs of these LifePo4 batteries with evaluations / comparisons and sourcing (with links/prices)
Here's some examples
- Fortune LiFePO4 Battery Cells: I love them! - https://youtu.be/buNxclZixuU
- Cheap 120Ah LiFePO4 Al Cased Aliexpress Cells: Are these Grade B? - https://youtu.be/p_s53GGUElQ
My sense is that this guy is 'for real', been at this a long time, and pretty up to date. At the least, I think you can get a good idea ofwhat a tear-down is like on some of these "12v batteries"... some are gooky and some are even smelly Smile
(02-29-2020, 10:25 PM)OffGridInTheCity Wrote: A youtube channel "DIY Solar Power with Will Prowse" if full of recent videos on tear-downs of these LifePo4 batteries with evaluations / comparisons and sourcing (with links/prices)
It's funny that you say smelly because at the moment all I've got is 2x old 12v 100a/hr SLA in parallel of which one bad cell pulls it down to 12.3v. I just have a timer and arduino-controlled relay with voltage sensor to spend a few minutes each day topping them up to 14.2v then turning off, just in case we lose power and need a very short term supply.
Oh yes that's what I was going to say - smelly! Charging the lead acid batteries is smelly enough (very modest whiff though granted.)
(02-29-2020, 09:26 PM)slimf Wrote: 3.2 x 123ah x 8 gives you ~3kwh = 1100 + postage
Yeah they work out about the same per watt-hour (within about 3.5%.)
Know how much you can get 18650 cells for each total cost in Australia if I was going to get around 600 of them?
Although after I end up spending a few hundred on tools etc. I'd prob only save a few hundred using 18650's for a 5kw/hr, with a greater chance of getting a dead cell to change.
