Recommend me a BMS for LiFePO4
I know that, isnt it obvious....
The BMS does limit charging, discharging LEVEL.
Everyone here seems to preach that a BMS is absolutely needed or all hell will break loose.
Thats why im asking wich BMS would be best.
I can already charge and discharge with what i have to any level
You wrote "Controll charging". If you need the BMS to talk to the chargecontroller. (Its doable) you need like Batrium or something and a charger that talk a common language doing it.
A BMS is not needed because else all hell will break loose. A BMS is needed WHEN hell breaks loose. Smile
Gato likes this post
#13
(03-01-2020, 05:24 PM)daromer Wrote: A BMS is not needed because else all hell will break loose. A BMS is needed WHEN hell breaks loose. Smile
Hopefully a BMS can trigger protective action BEFORE any hell breaks loose (when looks like it might be going bad soon... :-)
