Opus Fan Mod
@daromer most of the time they are used in Arctic-like environment, so I don't need parameters at high temperatures.
The ones that may end up in high temp areas are separately endurance-tested at high temperature.
My simple fan mod. Runs on 5v from the power supply so it doesn't pull too much air and affect the cells. Threw some legs on it so it can sit upright for easy viewing.
#13
The stopping doesnt change the total outcome much a d it gives all cells same deviation...
Note that IF you add a fan in middle of the test you need to retest all cells..
