Watchpower automation/alternatives?
Hi All
I have (finally!) commissioned my home solar panel, battery and inverter system - mostly due to the great advice on here - thanks to all!
I have  PIP5048MK MPPSolar unit that is working great so far, with 6 x 300W panels and a home-built 10kWh battery built from reclaimed 18650 e-bike batteries. I am using 'Watchpower' software to monitor performance and would like to store all the data that is currently available from the PIP unit. I can do this with Watchpower by exporting the data periodically (the PIP unit is permanently connected to a laptop via RS232 interface, and Watchpower is running continuously on the laptop).
Has anyone found a way of automating the data extract/export process - or do you use an alternative to Watchpower for data logging?
Many Thanks,
BarryG
Not much in life is free these days - but Solar Energy is!
I use Solar-sis that i have written and store it in influxdb and visualize with Grafana. For processing and automatization i use Node red
There is also an ISO for raspberry pi available
https://diytechandrepairs.nu/raspberry-solar/
You can install the solar-sis with NPM as well but its not latets version right now. Can be found on github to
(03-13-2020, 11:02 AM)daromer Wrote: I use Solar-sis that i have written and store it in influxdb and visualize with Grafana. For processing and automatization i use Node red
Thank you for the heads-up, daromer......much appreciated. I'll give this a look......
BarryG
