Maniac_Powerwall
Thank you all. These plates are made to mount on the outside of your house wall. The 'Fassade' we say in germany I think it is facade!? Smile
My Powerwall Build Thread
My Batrium had some kind of freeze yesterday. It was still working but no communication. Not on wifi and also I couldn't connect via USB. Hope this will not happen again. I needed to restart it. Now it is working again!?
Anyone having this issue before?
(04-04-2020, 05:11 PM)Maniac_Powerwall Wrote: My Batrium had some kind of freeze yesterday. It was still working but no communication. Not on wifi and also I couldn't connect via USB. Hope this will not happen again. I needed to restart it. Now it is working again!?
Yes - my WM4 (with expansion board) WiFi stops working 'now and then'.   Mine is under the house which has vents to outdoors but is not exposed to 'wind' or anything like that and the temp is steady 55F low in winter and 75F hi in summer.  I mention this because it seems to occur when there's a strong humidy or weather change - like a rain storm moves in or in early morning after a rain when sun comes up - which could cause humidy? or somthing to filter thru the vents and affect it.
 Its bizarre but has been ongoing for 1.5yrs now - ever since I got it.  Each time, I have to cycle power.      I upgraded (about 4? months ago) to latest firmware but didn't fix anything.
Because of this, I use a cheap laptop near the WM4 with USB cable/communication and then Remote Desktop into the laptop for info - and this fixed my problem as I don't use WiFi anymore. @Daromer has commented that his WiFi works perfectly when i brought this up a while back.
There is a reset button on the WM4. But I can't find how it works. Short press? Long press? I can cycle power but it seems easier to use the button. Couldn't say that there is any high humidity here at the moment. But didn't measure that.
hello maniac,
nice project, but I have some questions.
how many amps can do the fuse wires?
how much standby power MPP Solar PIP5048GK needs?
over a year of work means, how many working hours?
you find find the batrium problem?
greets from Berlin
marc
(03-26-2020, 12:34 PM)Wolf Wrote:
(03-26-2020, 11:53 AM)Oleksii Wrote: How did you print those capacity numbers on cells ?
I think I can answer that for Maniac_Powerwall.
look at the first picture in the tread https://secondlifestorage.com/showthread.php?tid=8872
P
rinter Printer Printer
hmm, is it possible to print directly on cylindrical cell ?
@ Oleksii: No, its just a simple label writer. It's printed to adhesive and I put them to the cells.
@ hardy: Standby is about 70-80 Watts. Quite high. You can double the usage for calculations. In my case I use 100 watts and there are barely 200 watts pulled from the battery.
For now Batrium works without any issues. Hope it stays this way :-)
Fuse wire is rated 5 Amps. But I think it can handle some more for a few seconds.
I don't know how many hours for sure but some hundred hours for everything!?
Had again two times in the last week that the Wifi of Batrium fails. System runs perfect but no Wifi via USB i am able to connect.
Very annoying since every time I need to restart the Batrium and it cuts my Pack from the inverter.
Any idea how I could solve this problem?
