Weld or solder?
powerX
New member
What are your opinions about this?
I found out, that welderis faster, better to the cells (not heating them up) but there is no way to use fuses. I like the way Hbpowerwallis using thin wire as a fuse for each cell. But that's not possible doing weldering. While fuse in my opinion is veryuseful option and can prevent a bad scenario...
Fullt possible. Yes you need to solder it into the busbar but Still faster.
